Dear Headfellows,
Bad news: Production of the CLASSIC has been delayed. For the powersupply I want to have Nichicon FG-series capacitors installed (these are the highest grade audio-capacitors they make) but unfortunately Nichicon is not able to deliver untill November/December. It may all have to do with the earthquake-catastrophe in Japan.
Of course, other capacitors could be used, including the FW-series made by Nichicon, but testing has revealed that the FG-series capacitors really do make a difference. Therefore I decided to wait a little bit longer. Please understand.
The amp will be worth the wait though, promised!!
In the meanwhile let me answer a few questions:
> will it stack above a stagedac ? i mean will the dimensions be the same as stagedac?
Yes, the amp will be equally wide. It will just be a little bit higher, due to some large size capacitors.
> The Classic will not have a DAC. This is the next evolution of Meier's top-of-line headphone amplifiers so we can assume the 64-step attenuator and active balanced ground.
Confirmed!
> What is new is that this appears to also have a preamplifier function.
Sorry, but it hasn’t!
> The evidence of this is that the Crossfeed switch has the 'speaker mode' that widens the sound image with speakers.
No, the crossfeed now has three levels (top-to-bottom): High, stereo, medium
Also this crossfeed is active over a much wider frequency range than the filter commonly found on CORDA amplifiers. In that it is comparable to the crossfeed on the STAGEDAC. The result is a more precise imaging.
Cheers
Jan
