Thanks for that clarification. I understand both ends of this cable are terminated with 4-pin XLR. Are the connectors male or female? Also, can you confirm that the same cable is shipped regardless of the specified input impedance of the transformer? (I assume yes.) Finally, is the 32-ohm transformer more linear (or otherwise preferable) to the 8-ohm version?
We appreciate (even more) your time on a holiday weekend!
You are most welcome and thank you!
The connectors on both ends are male.
Yes, same type for both 32 and 8 Ohm impedance options up to standard 1.5m (5ft.) length.
For greater length than that, we are using different topology cable with larger cross-section of Copper, as we need to keep resistance low enough for transformers to work properly. We can do up to 6m. (20ft.)
Both transformers have the same bandwidth (linearity). The parasitics in those transformers are governed by the secondary circuit and we just use the primary to multiply that by a desired ratio, so as we multiply impedance, we also multiply the parasitics by the same ratio, so the influence is proportionally the same and no difference in bandwidth.
However, keep in mind that there is no need for more than 4-5 Watts developed at either impedance by the amp.
So, if you have a powerful speaker amp (of linear electronics kind), use 32 Ohms as it will develop 4x less power at 32 than on 8 Ohms, so the headphones will be in less danger. transformers will start to saturate in low bass at over 6w and provide some protection, but that is not as effective as being mindfull with the volume pot.
Class-D amps are different. Their output filter is designed to see 4-8 Ohm loads (normal speakers) to be effective in cleaning up the switching noise.
So, for those, use 8 Ohm Inetrface, but really be careful with all that power available.
