Hi,
Thanks a lot for the reply. I guess chinese new year holidays are over now
I'll check with the reseller/dealer indeed.
One question : will the RC-3T remote control work with other devices from Shanling ?
If it's difficult to work out with the dealer is it possible to buy a RC-3T somewhere ?
Or do you know of any other remote control that wold be compatible ?
For the freezing : you are obviously aware of the problem.
Any chance you're working on a fix ?
Especially since Eddict terminates the Synclink connection really often (sometimes the connection terminates after 1 minute or so... sometimes it sticks for several hours. Totally random behaviour).
It seems like performing a total rescan of the USB stick from time to time helps the system to not freeze...
Regards.
The same remote works over the current lineup of devices (EC3/ET3/EH3)
It's possible to order spare through distributors.
We do not have any info on compatible 3rd party remotes.
So far have no update from software team on this issue.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
