Automatik
- Feb 20, 2016
Does anyone knows if the amp/Dac that comes with the kse 1500 is actually a SHA900 or is it smthg complitly different?
Don't know about the DAC but the amp portion is definitely different.Does anyone knows if the amp/Dac that comes with the kse 1500 is actually a SHA900 or is it smthg complitly different?
Question for my fellow KSE owners, is it just me or are the cables cumbersome and easily tangled. I find myself checking them every night to make sure the ribbon is not permanently bent. Also, I noticed on my first set of cables if a permanent bend develops the impedance must rise because I was running the volume up at least 2 steps to compensate.
The cable brings out my ADHD.
I think you meant OCD
Thanks, so I thought, but since they pretty much looks like the same, better asking than assuming....I wish I could give it a try one day soon .
They don't because their triples leave lots a room between the end of the tip and end of the nozzle. Wax shouldn't be an issue if you casually check it now and then. More wax than that would probably affect your hearing anyway. The shorter black foam (olives) tips incorporate wax guards.
Thank you for your reply. ER4S's triple flange sleeves also have a room but still their wax guards work well. I think it is better to support wax guards for safety, even if we use triple flange sleeves. any good ideas?
