Brando
- Nov 4, 2007
double post
How do you have the D90 connected to the A90? Are you using RCA cables? My understanding is that the noise issues can be avoided if you use the balanced XLR connection instead.I just got my new A90 hooked up top my D90 and right away noticed buzzing/static noises when I move my mouse and open programs. This is with the usb cable that came with the D90 hooked to my pc which is my source for everything. It didn't happen with the THX AAA 789 and nothing else has changed. Has anyone found the fix yet?
I had the same thing with my Feliks Audio Echo connected to Aune S6 which was connected via USB to my PC. The USB cable was the source of the noise, but it disappeared when both the DAC and the AMP were connected to the same power strip. Try that.I just got my new A90 hooked up top my D90 (rca) and right away noticed buzzing/static noises when I move my mouse and open programs. This is with the usb cable that came with the D90 hooked to my pc which is my source for everything. It didn't happen with the THX AAA 789 and nothing else has changed. Has anyone found the fix yet?
The D90 is connected to the A90 with some 6" schiit audio rca cables. The A90 and D90 are both plugged into the same tripp lite conditioner. If I use balanced xlr between the D90 and A90 will I still have single ended output? My ah-d7000's don't have balanced cables.
this is the line conditioner https://www.amazon.com/Tripp-Lite-LC1800-Conditioner-Outlet/dp/B0000514G8
thx 789
I guess that's another positive to switching to the A90. I can finally go true balanced if I get my phones cables switched. I feel bad for anyone that gets this and only has rca out but alls well that ends well I guess.it was also fake balanced
I´m on the same boat. I think Jotenheim2 will be. People who got the jot2 now, owned a90 before, sold a90. They say A90 it's like hospital clinical... like singer always sounds few years younger... measures very good, sounds too much... clean... jot2 more class A sound... proper real knob, 100$ less price... 5 years warranty fr the Schiit. If you are in USA, I think it's very clear what's best to get at the moment, no?
for a bit of a warmer sound?
