leo5111
- Sep 5, 2005
which amp is best if you like your music warm? the t01 seems to use same amp as a Cowon?
The beauty of n6ii, you can enjoy many different flavors, my favorite being R01.which amp is best if you like your music warm? the t01 seems to use same amp as a Cowon?
Haven't tried the R01, but of the others my favourite is the E01, I like the body that the mids have, especially in Class A amp mode.The beauty of n6ii, you can enjoy many different flavors, my favorite being R01.
Get the UAPP player in the Google store. From within that app, you should be able to access Tidal. I use this app on Android players 99% of the time, not just for streaming (I use Qobuz).I recently picked up an N6ii. Seems to be issues with Tidal. Half of the music i try to play in Tidal, comes up with an error nessage, itll say there was an unexpected error try again later with a series of numbers after the message. Tried uninstalling app and reinstalling, tried reset, ckearing cache. Is Tidal not really supported in this app anymore. I downloaded the app from the play store. Also tried Amazon music it was worse. Any ideas much appreciated. Thanks.
Fantastic, problem solved. Thanks a million. Sounds great now also.Get the UAPP player in the Google store. From within that app, you should be able to access Tidal. I use this app on Android players 99% of the time, not just for streaming (I use Qobuz).
It's a great app, one I was happy to pay for - and the additional price to unlock the amazing parametric eq is worth it as well.Fantastic, problem solved. Thanks a million. Sounds great now also.
+1 re UAPP. The other option I’ve used in N6ii is the native Roon app using the DAP as an endpoint via WiFi (you can select in Roon under setup). This allows me to use Roon’s DSP on N6ii. There is PEQ in UAPP; however I prefer bit-perfect mode in that app and to apply DSP via other means eg DSP in Mojo2 connected via LO from N6ii.It's a great app, one I was happy to pay for - and the additional price to unlock the amazing parametric eq is worth it as well.
UAPP is not the only solution for sure. Also, Neutron player is similar in functions to UAPP, so may be worth a look!+1 re UAPP. The other option I’ve used in N6ii is the native Roon app using the DAP as an endpoint via WiFi (you can select in Roon under setup). This allows me to use Roon’s DSP on N6ii. There is PEQ in UAPP; however I prefer bit-perfect mode in that app and to apply DSP via other means eg DSP in Mojo2 connected via LO from N6ii.
