I have read through Rob's opinion on the stock wall wart being sufficient, a battery eliminating any problems that may exist in the home power supply, the Qutest having galvanic isolation, and an unplugged laptop being ideal as well.
I generally agree with everything Rob says. Certainly an unplugged laptop is King so far. But power wise I do have to disagree. I tried battery packs, and they were ok/good/not much of a difference as compared to plugging into the wall. I did however NOT find any kind of battery power that was ideal. The battery Rob suggests in unobtainium, and I cannot find a battery that is native 5V, not 3.7v noisily switched to 5V.
I got a small but definite improvement by plugging the Qutest into a Power Isolator. I considered the issue of Power to the Qutest solved a long time ago, with Rob's untouched godlike reputation as an oracle still in tact.
Then there was a discussion on another thread about whether there was merit to creating clean DC power, even if using a high quality power isolator. Theoretically I thought, yes, a specific device to create clean DC power would do something different that a power isolator/AC power cleaner doesnt do. I found a local dealer of an "entry level" DC power creation product, the Sbooster, and gave it a demo.
I no longer believe EVERYTHING Rob says. Just most of it. Replacing the wall wart can make a big difference, but as with anything, the system is only as good as the weakest link. I was shocked that the $469 CAD price point 5v dc power Sbooster made such a difference, I was expecting to maybe see a small increase, like upgrading a power cable, or putting some vibration control under an amp, or no benefit at all. I thought I might have to spend the big bucks if I wanted even a small improvement.
I definitely feel that for 20% of the price of the Chord Qutest, I got a deal as everything just got noticeably better
I have a almost full range loudspeaker setup with a fully treated room. I noticed the timbre was instantly more natural, even if I didn't understand before what Timbre was, it was just better, and I instantly understood what is was. The background details crystalized together clearer than ever before. The first 3 tracks I played from my collection of reference tracks Ive played hundreds of times brought 1+ new discoveries per track. The difference isn't debatable. All of a sudden I was able to determine which of my favorite tracks had subtle harmonies and which were just echos or instruments that complimented vocals. Certain tracks had vocals in the background that added a general ambiance to the music, but that now became distinct entities themselves. All of a sudden I could follow every word and nuance of the choirs in the background, even when they weren't thrust prominently to the foreground for a chorus.
As for the Sbooster, I know it works, but Im not sure if similar results can be had for less money, or if better results can be had for more money.
What I do know is that Rob Watts is full of crap RE: stock wall wart. And this is probably the only time ever I will get to say that
