gordec
- Aug 14, 2006
What headphones/earphones are you using? Is the volume control problem consistent with all of them? I found volume change to be pretty smooth, you have 140 steps, very granular adjustment. Have you tried turning the headphone mode on/off (in Quick Setting menu) to see if that will make any difference (headphone mode on is for higher impedance cans and gives you power boost, I wouldn't recommend using it with IEMs).
The Cowon P1 has amazing synergy with the ES60. Let me know what you think of the M2 with your ES60. They should be an amazing pair.
