No the microUSB port on the M2 can only do incoming data, not send data out. You can send digital signal out of the M2 using an optical cable, but you'd need some kind of optical to USB converter to get it into the M11Pro though.Is it possible to connect M2 to another DAC/AMP vis USB?
I am trying to connect M2 to M11 Pro via USB but I am not getting any sound out of M11 Pro.
Cowon PLENUE M2 (Current Firmware and Manual Links in 1st post)
- Thread starter taffy2207
dsrk
Ok, thanks.No the microUSB port on the M2 can only do incoming data, not send data out. You can send digital signal out of the M2 using an optical cable, but you'd need some kind of optical to USB converter to get it into the M11Pro though.
jmills8
Previously known as bmiamihk, jmills2
M2 to Hugo 2Ok, thanks.
dsrk
I never used JetEffects presets before, I always used the custom EQ. I have been using the BBE presets for the past few months and boy are they amazing.
It's really a shame Cowon discontinued this little gem.
jmills8
towanda
- Nov 26, 2011
Am I able to buy this 16 hour battery pack, somewhere? Is the ROMI internal mod a mod to your DAP or amp?
Cheers
Cheers
jmills8
Romi installed the battery , and Romi changed some internals to improve the sound.Am I able to buy this 16 hour battery pack, somewhere? Is the ROMI internal mod a mod to your DAP or amp?
Cheers
Zozo11
How does the PM2 compare with todays daps?Romi installed the battery , and Romi changed some internals to improve the sound.
Zozo11
Looking for another dap and love this set up. What's your preferred Cowon and are the amps still
Looking for a new dap and love this set up. What is your preferred Cowon and can the Arrow amps still be purchased?Im using it almost everyday and Im just charging it once every 3 weeks.
jmills8
I like the PS , PM2 , then PL (it has a 4.4 balance). There are Arrow on sale used or go for a Romi amp , it gives 5 watts.Looking for a new dap and love this set up. What is your preferred Cowon and can the Arrow amps still be purchased?
Zozo11
Thanks, looking forward to it.I like the PS , PM2 , then PL (it has a 4.4 balance). There are Arrow on sale used or go for a Romi amp , it gives 5 watts.
pholcus1975
Just to say, my PM2 still runs 7,5 hrs at volume 70 high gain, 16/44.1 flac. No need to buy a new DAP, it still sounds so good. Only temptation is a Plenue L, but it's so hard to find.
Zozo11
Cowon will re-release the PL in the future, not too sure when tho, enjoy the PM2 it's awesome!Just to say, my PM2 still runs 7,5 hrs at volume 70 high gain, 16/44.1 flac. No need to buy a new DAP, it still sounds so good. Only temptation is a Plenue L, but it's so hard to find.
jmills8
.Cowon will re-release the PL in the future, not too sure when tho, enjoy the PM2 it's awesome!
