Deleeh
Hello,
You must be lucky to find a Spring 3 used, they are usually gone very quickly.
In this regards R26 is very good: spatious and holografic. I dont want to say it loud but i had the Holo May KTE before the R26. If you can get the R26 second hand, it is a bargain.I feel like the HE works great as an All-in-one solution and it certainly delivers great value for its money but it does have its shortcomings. While being musical and convenient to listen to, it is not the most resolving nor does it have great sound staging. I find it also to be lacking a bit in realism and tonal depth.
The Holo Spring 3 seems to outclass the Naim HE DAC in each of those aspects. I might just have to buy it blind on the used market and see for myself.
does the R26 come close to the May in terms of space and separation? How exactly do they differ? From what I have read about the May it should outright destroy the R26, right?In this regards R26 is very good: spatious and holografic. I dont want to say it loud but i had the Holo May KTE before the R26. If you can get the R26 second hand, it is a bargain.
Yeah, when you jump on the hype train, than May is the bestdoes the R26 come close to the May in terms of space and separation? How exactly do they differ? From what I have read about the May it should outright destroy the R26, right?
I don't quite agree that R2R DACs work best or even require software upsamplers. For Delta Sigma DACs there is a clear reason, but not for R2R DACs. It would sound different , you may like it or not, but better?. at least I don't find any technical reason that would explain that.....These DACs are also best used with HQPlayer or PGGB upsampling, sentt to DAC in NOS mode. I expect that this would be a good plan for R26 as well.
No, but there are many hundreds of posts about it here and elsewhere, and it is my own experience as well.
I am not interested in ASR style analysis and discussion.
Thanks for your comments!Sad that you had to sell Bliss, but that can always be replaced in the future if necessary. It’s great that you have a cache of 6SN7 tubes to get you started, though if you follow this and the other threads, you may want to explore the rabbit hole more deeply.
Then there is the 300B rabbit hole…
And congratulations on the Envy!
