Jayden16
- Apr 29, 2016
Good to know, thanks for the response!X1ii has more than enough output to power the P1 - you shouldn't need any extra amping.
It's been a few days now...you've been quiet all week. How's things a'goin with your X1-II?When things work as they should, I will say as much. When they do not, I will all so say as much. Again, I think what has happened to early buyers is nothing short of wrong and FiiO could offer some small consolation to those that put up with being beta testers. And again, I do not know their margin of profit but if they can do some thing for those people, then I think they should.
And by this I mean the folks here that bought in good faith and continued to with FiiO to get this DAP right. I am not concerned with the whole world, just those that I know via this little corner of the Matrix. Regard less, FiiO has made it right by fixing it. Finally.
ORT
So far, so good. I have not noticed "gapless" working (and I selected it). I have not tried out the blutoof yet. I can not comment on the musicalifragelisticexpealidocisousness of the X1-II as, well...I have not heard any thing other than music. My blutoof helmet is at work so as I said, I have not tried out that aspect yet.
It works fine via USB in my car or via the mini-jack in my car. The former displays info on the car's radio screen while that latter does not. I like the rose color just fine and my daughter said she does not want the unit so I do not have to order up another.
ORT
I have the same problem as you and reported it a few days ago.My X1 II refused to "return" to the main menu. It would just keep playing the same group of songs, over and over. I could turn it off, wait a few minutes, turn it back on and it would still be stuck on the same group of songs. Played only in order. If I tried to use the "return" feature the screen would turn black with the music playing. I could not do anything but power down.
I finally turned it off, removed the MicroSD and then turned it back on. It was at the main menu. With the power still on I inserted the card and every thing worked again as it had. FiiO, would you happen to know if this was just a problem I encountered or have others experienced it or some thing similar? I have not tried Bluetooth yet. I just listen to my music.
Which is exactly what this is designed for. I await any insight from FiiO. Thank you.
ORT
Thank YouUnfortunately, the equalizer isn't supported through bluetooth ... no setting to change...
ORT
"I have a similar problem. Everytime I listen to the songs of a single artist or of a single album, I can´t switch back to the categorie . When I try to skip back, the monitor turns black and no further action is possible. To start the X1 again I have to longpress the on/off button.
I have reported this issue before and they told me to reset my device, but this isn´t a solution for this bug.
I hope Fiio can solve this problem in the next firmwareupdate. Until then, I can only use the random play of all songs, but that´s not what I bought this player for."
I only find this solution:
- I reseted the device
- I formated the card new, that means I deleted all songs!!!
- I sychronized the device new (I use the programm "MusicBee")
- At least I have to actualise the media library by hand (manual).
All in all, this takes it time, but it is worth spending. In the moment I have no problems, no black screens, the player works fine.
I hope this will help, so you can enjoy our little player.
Dear friend,I just received my X1 II. It sounds great. However, I noticed that the equalizer doesn't function when listening through bluetooth. Is it supposed to? Is there a setting I need to change? It works fine on through the headphone output. I've installed firmware 6.6.
Dear friends,
Seems you are both meeting the issue with black display when pressing the back button in playing songs from category. We have reported to our engineers about that and trying to reproduce and solve the issue. We are sorry for bringing inconvenience to you. You may try to do a factory restore for help by now.
Best regards
Hi everyone, i have been using my fiio x ii for a month and i'm overall (very) satisfied but a problem just occurred (or maybe it started before but i didn't realize it) : when i play a song within an album and the player is showing the cover of that album then the informations that used to appear above that picture (name of the file, name of the folder, mp3 or aac or flac (depending on the file obviously) + 44.1khz or 192khz) disappear within the first seconds of the song.
That problem (informations including the name of the album + the type of file mp3/aac/flac) doesn't occur when i switch to "no" the "show the picture of the album" setting.
I don't know what to do, i'm either forced to keep the cover of the albums but i'm missing the name of that album + file informations or switch off those pictures to keep those informations visible during the whole song (and not during less than 5 seconds at the beginning of it).
I tried to restore the fiio to the default settings but it didn't fix the issue.
Thanks for any help you could give me, and sorry for my flawed english
NB : my fiio x1 ii has been on 1.6.0 for about his whole life except the first 10 minutes i got it (it was on 1.5.6 and i immediately upgraded it)
Have you tried reinstalling the firmware, or doing a hard reset?
I'm not sure if it is supposed to act this way (?)
