You were right. The stock cable was ok...until I got a 22awg Fog City Cable and now I can't use the stock...it just sounds wimpy with it. The difference is substantial.
The Clear's sound great with a Violectric amp, but I switched over my Valhalla 2 with Bugle Boys and they sound great and bassier. I can't believe I haven't put these on in more than two and a half months.
What a sweet sound! Mids and bass are SO good together.
I have to stop being so democratic with my headphones!
I LOVE my OG Clears. It's my only headphone that I don't have to software EQ some glaring flaw. That is after replacing the stock cable and stock ear pads though. Anyways, it sounds great with the xDuoo TA-22. Is there an amp that pairs well and expands the soundstage of the Clear, or a headphone that's similar with a more expansive soundstage?
Possibly Hifiman Arya Organic it's going to give you a more noticeable soundstage increase as well as HD800, but it's going to be very different in their sound signature. All of my focals sound absolutely amazing from my Shanling H5, and also the Aune S17, but there's some caveats with the Clears, just don't push them really hard with this amp.
I definitely agree with Shane on Clear OG with low/mid output impedance tube h/p/a! As much as I enjoy Clear OG + Violectric, the right tube h/p/a turbocharges Clear OG performance ...
I LOVE my OG Clears. It's my only headphone that I don't have to software EQ some glaring flaw. That is after replacing the stock cable and stock ear pads though. Anyways, it sounds great with the xDuoo TA-22. Is there an amp** that pairs well and expands the soundstage of the Clear, or a headphone that's similar with a more expansive soundstage?
The sound that comes from the S17 and Clear's combo it's just amazing, and keep in mind I have a pretty low tier DAC, so with a better DAC it would sound even better.
In 100ma mode, low gain, the sound it's incredibly deep and holographic and also lush, kind of warm, bass it's also very punchy and extended, probably to much for the poor clears drivers, this is where the caveats come in.
On 100ma mode, low gain at around 45 on the volume is as loud as I can play them before they start clipping and distorting, I taken away all EQ on Roon, sometimes I can push them to 48, it might be my particular set of clears that are the problem but already try them out with my Shanling H5 and I don't have this problem with that portable amp even at higher volumes than with the S17.
If you want to know what I'm listening that has me concern, for example we have Q from Aethek, Lustmord from the Scorn soundtrack, when the deep drum comes in that's when they sometimes clip.
I just be careful how hard you push your Clear's if you decided to buy the S17, every other focal headphone it's fine and sounds excellent on this amp, it's just with the Clears that I have this problem.
