Introducing Shanling M9 Plus - Updated Flagship Portable Player
Nov 18, 2023 at 7:15 PM Post #61 of 69
Nov 19, 2023 at 8:21 PM Post #62 of 69
Mar 8, 2024 at 6:22 PM Post #63 of 69
Hi @Shanling
What is the power output on the Line Out option?
Trying to see if it exceeds the recommended inputs on some portable amps, in which case I will use PO instead.
EDIT : Sorted.
Mar 10, 2024 at 9:20 PM Post #64 of 69
Hi @Shanling
EDIT : Sorted.
Here are the values:
3.5mm
Low Gain 0.8V
Medium gain 1.5V
High Gain 3V
4.4mm
Low Gain 1.5V
Medium gain 3V
High Gain 4V
Mar 11, 2024 at 1:55 AM Post #65 of 69
Can be found on the Homepage - Shanling is always publishing all the detailed specs on the product page: https://en.shanling.com/product/433
Apr 10, 2024 at 9:23 PM Post #66 of 69
