Halimj7
- Mar 2, 2012
Sony is an audio legend. I just wish they would make a current TOTL headphone I like.
The xb1000 isn't your cup of tea?Sony is an audio legend. I just wish they would make a current TOTL headphone I like.
Could these be considered a closed back HE6se V2? PLEASE...We are very excited to introduce our all-new HE-R9, the Closed-Back Dynamic Driver Headphone!
The new HE-R9 features high sensitivity thanks to the use of rare earth magnets and our classic Topology Diaphragm for detailed high-frequency response to 35kHz. By applying nano-scale particles to the diaphragm in a variety of patterns and layers, a high-level optimization occurs, having a positive effect on the audio characteristics.
The HE-R9 is designed for extended listening sessions. The headband features high-grade memory foam for maximum comfort and elasticity. The headband skeleton is made of steel that is lightweight and strong. On the outside, real leather gives the R9 a soft and elegant appearance. Newly designed earcups are large for substantial volume and exceptional overall acoustics.
For compatibility with the highest range of sources, the HE-R9’s socket accommodates both dual-sided 3.5mm and single-sided balanced cables. The addition of HIFIMAN’s Bluemini R2R dongle* turns the R9 into a high-resolution wireless headphone.
HE-R9 Headphone Specifications:
Frequency Response: 15Hz-35kHz
Impedance: 32Ω
Sensitivity: 100dB
Weight: 328g
3.5mm balanced socket on the left
Learn more: https://store.hifiman.com/index.php/he-r9.html
I have seen multiple over the years, but none of them was from this particular headphone.Anyone seen an FR graph ?
See post # 5How has no one mentioned/noticed that the cups look EXACTLY like the finish on the TH900?
Like uhm, those are Fostex cups, Hifiman....
Well played, sir.I have seen multiple over the years, but none of them was from this particular headphone.
I wish I had heard it when it was current and readily available. What is its sound signature?The xb1000 isn't your cup of tea?
What is the audience for this headphone? Is it meant to compete with the Airpods Max?
BASS.I wish I had heard it when it was current and readily available. What is its sound signature?
Classic lol. Is the bass tight, loose defined? Thanks.BASS.
It's a wide band bass boost from 20-300ish hz. Smooth midrange and relaxed enough treble. The bass though is just so powerful. The ear pads also help make the bass feel much more than it actually is. Really good for modern musicClassic lol. Is the bass tight, loose defined? Thanks.
