Andrew_WOT
- Jan 18, 2004
Try different source as suggested PC (the best) or other Android phone (Apple is always finicky), could be USB chip compatibility. I believe HiBy FC6 had similar issue on SnapDragon 8 phones.Excuse the question but what smartphone are you using it with? Apple? If so, try it from computer or android and see if it has the same fault... if it doesn't, the problem is the iPhone... obviously.
Update to the latest FW, check OP.
