Luxury & Precision (LP) W4, Successor to Their Popular W1/W2 USB Dongle is Here!
Aug 4, 2023 at 11:40 AM Post #992 of 1,440
Since Musicteck doesn't want to replace it, it means that LP is confirming that having a popping effect is not a defective unit and is probably caused by firmware.
When you contact the authorial dealer about replacement, they first request the manufacturer about the problem.
Wouldn't we have more affected users if that was the case?
Aug 4, 2023 at 2:18 PM Post #994 of 1,440
Appreciate all the help, and thankfully Musicteck is allowing me to return it for store credit. Looking at purchasing the Cayin RU7 with some money left over for a pair of IEMs.
When you hear the RU7 you will thank the W4 flaw... lol
Aug 4, 2023 at 3:35 PM Post #995 of 1,440
Ok so I finally received my W4 last week, unfortunately my local store didn't receive any cases and I could really use one. Are there any stores in Europe that have the cases and sell them separately? Audioessence only allows them to be bought bundled with the W4
Aug 4, 2023 at 3:53 PM Post #996 of 1,440
Buy from here :
US $29.00 50%OFF | Lebi W4 series magnetic suction top layer cowhide handmade leather case
https://a.aliexpress.com/_EG3rUfd
Aug 4, 2023 at 4:39 PM Post #998 of 1,440
Well, that has me worried. Is there another DAC you'd recommend I look at?
Why? I said you are right... however if you prefer a more delta/sigma sound and low power consumption you can also consider a Questyle M15.
Aug 4, 2023 at 5:40 PM Post #1,001 of 1,440
Aug 5, 2023 at 8:13 PM Post #1,003 of 1,440
Both my W4 & W2 have stopped working with my iPhone 13 Pro Max. The dongles power on and look like they’re connected, but there’s no sound. I’ve tested both dongles with an Android device and they still work perfectly, so the issue seems to be isolated to my iPhone. I’ve also tried using a different Lightning to USB-C cable but that hasn’t helped. Anyone else have this issue? I’ve tried the obvious stuff like rebooting the iPhone and closing/reopening all apps etc. and my apple 3.5mm dongle is working perfectly fine.
Aug 5, 2023 at 11:56 PM Post #1,004 of 1,440
Aug 6, 2023 at 12:43 AM Post #1,005 of 1,440
Which iOs version do you use? I am using the newest iOs on iPhone 13 Pro (16.6) with W2, both work flawlessly
