latest iOSWhich iOs version do you use? I am using the newest iOs on iPhone 13 Pro (16.6) with W2, both work flawlessly
Luxury & Precision (LP) W4, Successor to Their Popular W1/W2 USB Dongle is Here!
- Thread starter bluestorm1992
What phone can you recommend that will work with full potential power, even with Ru7?
Yep, same issue with my iPhone 13 Pro, but the W4 worked fine with my daughters iPhone 12, and my iPad Pro.Both my W4 & W2 have stopped working with my iPhone 13 Pro Max. The dongles power on and look like they’re connected, but there’s no sound. I’ve tested both dongles with an Android device and they still work perfectly, so the issue seems to be isolated to my iPhone. I’ve also tried using a different Lightning to USB-C cable but that hasn’t helped. Anyone else have this issue? I’ve tried the obvious stuff like rebooting the iPhone and closing/reopening all apps etc. and my apple 3.5mm dongle is working perfectly fine.
My iPhone would recognize the W4 device, and seem to play through to it, but I got no sound. I wonder if there’s been an iOS update specific to iPhone 13’s that‘s caused this, if both of your W2 & W4 worked previously..
Strangely, mine is working with my 14 ProBoth my W4 & W2 have stopped working with my iPhone 13 Pro Max. The dongles power on and look like they’re connected, but there’s no sound. I’ve tested both dongles with an Android device and they still work perfectly, so the issue seems to be isolated to my iPhone. I’ve also tried using a different Lightning to USB-C cable but that hasn’t helped. Anyone else have this issue? I’ve tried the obvious stuff like rebooting the iPhone and closing/reopening all apps etc. and my apple 3.5mm dongle is working perfectly fine.
I'm running iOS 16.6 and LP 1.0.1.6
rwelles
My W-4 works fine with my iPhone 13 mini. Running latest iOS. what music app are you running on your phone?
Andrew_WOT
- Jan 18, 2004
I am Android/PC guy, they all work, sorry, perhaps that doesn't help your case.What phone can you recommend that will work with full potential power, even with Ru7?
But it sounds crazy replacing the phone for dongle compatibility, not sure if you were serious with your question.
My W4 with Ru7 should arrive end of the week. If W4 will not work great with iPhone, will buy an Android phone. As I know, not all Android phones support the full potential of OTG audio dongles, and some of them also limit the power.I am Android/PC guy, they all work, sorry, perhaps that doesn't help your case.
Turns out there was an iOS update I needed which has now fixed the issueStrangely, mine is working with my 14 Pro
I am happy to read that. W4 is an awesome USB DAC.Turns out there was an iOS update I needed which has now fixed the issue
I placed the order, maybe you're right and it'll arrive fastThat use to be the case for UK, but now everything arrives in 7 days, at least for me.
I am glad you did. After all the original case is really nice apart from not offering 100% protection. Just be careful with it.I placed the order, maybe you're right and it'll arrive fast
I just got my W4. Compared to the W2 OG, it sounds darker, and the bass is quite different. Instead of having fakely boosted sub-bass, it has more linear bass but, to my ears, still fakely slightly boosted. Fakely - means with DSP. But sound more mature and fuller, and there are definitely sound improvements. I need to find Windows PC to update the firmware. It doesn't want to work with Apple Camera Kit, so I can't measure power consumption from my iPhone. However, from my first impression, it still sounds worse from iPhone compared to the Macbook.
Update: My unit also clicks (pop) when I change or even scroll the music. It is only on 3.5mm output.
- Jan 30, 2012
It's a long shot, but I don't suppose anyone has a Galaxy Fold 5 and is using it with their W4?
I was at an audio store comparing the W4 and the RU7 today and for some reason the W4 just would only connect to my phone 10% of the time. The RU7 worked flawlessly every time. This was a real shame as I found the W4 to be really good actually when it did work, and paired with my IEMs better than the RU7 did.
Perhaps the store didn't have the updated firmware on their unit..? Any input would be appreciated, thanks all!
I am finally ready to say goodbye to my WM1A. W4 is so good it even surpasses WM1A with the resolution. It only loose to Sony with timbre.
Listening to Caligula's Horse - Dream the Dead with UE Live, Filter set to Slow, and Tune to 2, I never could imagine that someday portable dac/amp could give such a natural bass attack.
helloh3adfi
Anyone with Cayin RU7 can tell if RU7 or W4 is the better dongle?
