In your case I would go for ES60. ES80 stirs farther away from a "typical" Westone sound sig. Definitely a big improvement in resolution and transparency, but at an expense of a more neutral sound sig with less bass impact. ES60 will sit between W80 and ES80.
OK, you say this because ES60 is similar in resolution and transparency with W80?
What do you think about the 64 Audio CIEMs?
I really like the U4-SE and the Apex modules really works...
Are there any CIEM with the same footprint of U4-SE or similar in sound and transparency with W80 or ES60?
by the way, thanks for your help
