Aaron Friedman
Well, I received the AUNE S17 Pro and the Gustard H26 Headphone Amps. I also received the Gustard A26 DAC.
that is going to be very interested A/B comparison. everyone in the world is looking forward to see the review!!! thank you AaronWell, I received the AUNE S17 Pro and the Gustard H26 Headphone Amps. I also received the Gustard A26 DAC. The Gustard Dac is working well. Unfortunately, the Gustard H26 Headphone amp was DOA! Lucky I ordered also the Aune S17 Pro which is working well so far. I was going to AB them but at this point the only thing I can say is that the Gustard H26 is deadly quiet. I mean it turn on. I just am not able to get any sounds out of any of the Headphone Jacks. I emailed Shenzaudio about it. I am waiting for them to get back to
Sorry that I was not clear. The Gustard H26 Headphone Amp Was Dead on Arrival DOA! So unfortunately, Until I get a replacement, I will not be able to do the review between the 2 headphone amps. I am waiting for a response from Shenzen Audio. I emailed them about the situation.that is going to be very interested A/B comparison. everyone in the world is looking forward to see the review!!! thank you Aaron
Did you select correct input of your source and just in case did you double check your input is correct I sometimes got confuse xlr 1 and xlr2 coz they are so close together for the left and right.Well, I received the AUNE S17 Pro and the Gustard H26 Headphone Amps. I also received the Gustard A26 DAC. The Gustard Dac is working well. Unfortunately, the Gustard H26 Headphone amp was DOA! Lucky I ordered also the Aune S17 Pro which is working well so far. I was going to AB them but at this point the only thing I can say is that the Gustard H26 is deadly quiet. I mean it turn on. I just am not able to get any sounds out of any of the Headphone Jacks. I emailed Shenzaudio about it. I am waiting for them to get back to me.
Yes, I did it 10 times. The 2 middle ones are XLR1 and the 2 on the sides are XLR2. I tried both. Of Course, I changed the input from the front too. It turns on but non of the Headphone jacks makes a sound. I tried all 3 with both XLR inputs. It is almost like the power supply for the headphone Amp was not connected.Did you select correct input of your source and just in case did you double check your input is correct I sometimes got confuse xlr 1 and xlr2 coz they are so close together for the left and right.
That too bad. Hope you get replacement soon.Yes, I did it 10 times. The 2 middle ones are XLR1 and the 2 on the sides are XLR2. I tried both. Of Course, I changed the input from the front too. It turns on but non of the Headphone jacks makes a sound. I tried all 3 with both XLR inputs. It is almost like the power supply for the headphone Amp was not connected.
THANKSThat too bad. Hope you get replacement soon.
Your voltage is correct?THANKS
THANKS
Yes, it is pushed up so you do not see 115v right? You see the 220.Your voltage is correct?
Hi, Yes, the Amp Power is on. The Voltage are pushed up so you see the 220 number right?hi
1. Is the 110V/220V switch on the rear of the H26 fuselage in the correct position?
2. Is the third item in the operation menu: AMP POWER set to ON?
Thank you so much. Google and AI told me just the opposite. I thought it was right because the DAC was working. Sorry for the trouble. I looked all over in the manual and it does not show a picture that I could find. Again, my apologies to everyone.Please set it to the correct value according to your country's mains voltage.
The number displayed on the switch is the current setting.
