CosmicHolyGhost
Exhaustively burning holes in his wallet
- Jun 10, 2013
Moon audio cable is pretty well made... But whether one can tell the sonic difference between a $150 cable and a $350 one is highly subjective
Do you already have a XLR cable for your HD650? If so, I would just do XLR->TRRS.
No XLR, i just have the standard cable that came with the HD650 and have read that the silver dragon v3 is a very good replacement.
They are not balanced cans, unless it is the cable which determines if they are balanced. I'm not sure.
Jelt, Have you tried a hard reset?
Btw, are you from dadong or quanjude?
Which is it? Such totally different ducks, lol... The dadong at dongsi****iao is my fav. Queue is horrid though
Hello anyone has experienced the following problem with balanced amp card: if I put the gain on high while using the dap single ended, only the right ear is boosted. I do not need the gain but still this is a problem.
Was none of the above but I took out the amp card and put it back in and...problem solved...I feel much better.
Listening to my 1plus2 with silver gold...lovely.
Now what new friend to get for my 901? Fitear 335, 435 or Hidition NT6?
Me no likey cans. Me likey iems, and me not too much likey universals. Me want only TOTL CIEMS.what about some TH900s or LCD3s.... sound great on the balance amp and the discrete amp
