Home-Made IEMs
- Thread starter Bilavideo
swtnate
I usually only put the cap going to the wbfk. Usually that cap is .47 to .82uf.This is my scheme drawing
Hope it makes sense.
Hi everyone,
I started the hobby three years ago. I want to go deeper yet the diminishing return and the price is holding me back. Im still a student so I dont have the capability to buy really expensive iem. So I guess I'll start to make my own iem and in return customize my frequency response. I don't know much of building one but I believe I have enough skills working with resin and some circuits.
I plan to make a three driver setup with three way crossover, yet studying signal filtering, cause me confusion on why do everyone only use simple circuits.
Are these diagrams overkill? Or there are something Im missing out, like the drivers' resistance simplify these diagrams that makes them insignificant. Wouldn't there be any signal noise if these kinds of circuits were not used?
The diagrams in the first img are just my sketched diagram of what I think might be a three-way crossover. Is this applicable for an iem or is it just exclusive for speakers?
Something missing: How will you fit the components in the shell? I'd skip the notch filters at first.
Don't forget about physical tuning also, much more predictable than electronic. You have to use both together.
How you like the frequency response?I usually only put the cap going to the wbfk. Usually that cap is .47 to .82uf.
swtnate
Love it. It eliminates the dip at 4k and the big peak at 6.5. Its a flatter shelf with more highsHow you like the frequency response?
Looking great . Is this graph with same drivers I use?Love it. It eliminates the dip at 4k and the big peak at 6.5. Its a flatter shelf with more highs
And you probably use longer tubes for twfk
swtnate
Same drivers. Yellow damper on the 38. Twfk has about a 14mm tube with a white damper.Looking great . Is this graph with same drivers I use?
Did you only put .82 uf one twfk? Cuz once i put .82 uf on wbfk, the graph goes crazy , its shows cancellation . Thats why i just go with 22 cup .Same drivers. Yellow damper on the 38. Twfk has about a 14mm tube with a white damper.
May be problem with cap
swtnate
Try flipping the wires, or bypass the l-pad, to the 38
May be i got wrong caps lol.Try flipping the wires, or bypass the l-pad, to the 38
Where you get your caps ?
swtnate
MouserMay be i got wrong caps lol.
KZ PR2 with usound UT-P2018 mems speaker, dry fit. There is a clear angle to drill and connect the sound bore.
How did you power the MEMS?
I have the usound amp for a desktop / tuning solution, but planning to use the guts from some Fauna audio glasses for wireless and see how that sounds. I may need to revive an old cell phone to get access to a functioning Fauna app, haven't quite gotten that far yet. Finding a case and a battery for the usound amp would require big pockets to carry around, but is possible.How did you power the MEMS?
swtnate
Also, I use 1mmID tubing with a yellow damper. The smaller sized diameter will also not require much of an l-pad as it will squash the mids and highs peak(s). I usually just use a single series resistor in place of the l-pad. The l-pad I HAVE to implement when using the sonion 33 or even the knowles CI. Sonion 38’s with ferrofluid do not require too much tuning as they have such a natural slope.This is my scheme drawing
Total: 8 (members: 0, guests: 8)
