Okay ,thank you . Today ill put small Tube and 10 value resister .Also, I use 1mmID tubing with a yellow damper. The smaller sized diameter will also not require much of an l-pad as it will squash the mids and highs peak(s). I usually just use a single series resistor in place of the l-pad. The l-pad I HAVE to implement when using the sonion 33 or even the knowles CI. Sonion 38’s with ferrofluid do not require too much tuning as they have such a natural slope.
Home-Made IEMs
- Thread starter Bilavideo
Hey guys,
I have an issue with my desing for my IEMs . For some reason I don't have any bass with this design (the red line is the dd that I want to use it for bass). I know that I need to add and dumper but for some reason the bass without anything is mushy. There my be a problem with the dd?
Tubes diameter is 2 mm(I think I will make them 2.1 to allow me to add dumpers)
Can someone explain to me what I am doing wrong?
swtnate
being a dynamic driver, you have to take into account how different they are from armatures. I would say its either a resistance issue causing the DD to not get enough signal OR when the tubes were pulled through, it got pinched. Get a component tester and test for signal at every pad.Hey guys,
The tubes are made from resin, they are not soft tubes.being a dynamic driver, you have to take into account how different they are from armatures. I would say its either a resistance issue causing the DD to not get enough signal OR when the tubes were pulled through, it got pinched. Get a component tester and test for signal at every pad.
What component tester do you recommend(can I use a multimeter)?
swtnate
Yes. Theres multimeters made for SMD components thats easier to handle and testThe tubes are made from resin, they are not soft tubes.
From what I see you have a front-volume vent going to the top, this is why you got no bass, you need to partially block the vent with damper and vent the back volume of the DD at the same timeHey guys,
Tried to cover the hole and still no baseFrom what I see you have a front-volume vent going to the top, this is why you got no bass, you need to partially block the vent with damper and vent the back volume of the DD at the same time
I don't think that's the issue,
I tried to measure the dd only and the graph looks like this(only the dd is connected to the wire no other driver are connected in parallel, this is the driver https://huayunxin.net/product/huayunxin-dd-ht10). Something is off with the driver or the cable that I use, but I don't think the cable is the issue here(it's a kz 0.78 pin cable)
Do you know what are this pads for, or what they do and what I need to solder to them?
swtnate
Wire the whole circuit, including all components. Reverse the polarity on the Dynamic and standard connections to the armatures. Be sure ever driver in connected directly back to whatever connector you have chosen (mmcx, 2-pin, etc). Now, test polarity of the connected pads. Also, due to the amount of what looks like possible excessive THD and a lower observed SPL, you maybe dealing with some potential solder damage. Easy to do on these devices if you’re using an iron with a wider temperature tolerance. If you have an additional dynamic, wire it and test it as your standard response curve. Last thing, Ive had Knowles graphs be a little off here and there. But, I cant remember a single sonion driver where the tested eq graph came even the smallest bit similar to their lab charts. Your best bet at this point, is to cut bait if you another driver to test and insire proper functionality.Tried to cover the hole and still no base
clearly there's sound leak, you just have to find where.Tried to cover the hole and still no base
Use a piece of 1/4 or 6mm tubing, maybe 2ft long. Put an eartip on one end, use the other end to locate the air leak by pointing to different locations. Connect the shell nozzle to a bottle and squeeze slowly, or use some other method to gently pressurize with air. You will find it.
musmecca
The sound thief works...I have a pic of mine somewhere in here..Use a piece of 1/4 or 6mm tubing, maybe 2ft long. Put an eartip on one end, use the other end to locate the air leak by pointing to different locations. Connect the shell nozzle to a bottle and squeeze slowly, or use some other method to gently pressurize with air. You will find it.
swtnate
@piotrus-g is spot on. You could also have a leak between the IEM and the testing microphone. That can also give you a false reading.Tried to cover the hole and still no base
swtnate
Here is the testing microphone and adapter I have used for years, to test out custom IEMs. Dennie Miller has been an awesome resource and extremely helpful with an question or product support issues. Hands down would recommend him and his business to anyone. He also sells Smaart software. But, REW is still my go to software for ease of use. The adapter with this testing kit has a rubber gasket that stretches and holds firm to custom shell, eliminating thd need for the use if blue tack or any equivalent. Was a gamechanger for my development and growth. Thanks to @piotrus-g for setting me straight when I didnt realize the VALUE of such equipment.Tried to cover the hole and still no base
https://www.millerai.com/shop/p/iem-measurement-bundle
I wanted to build a pair of masm 7 but couldn't find bs6s. Any other build that is of good value? Or is there anywhere to buy bs6s in a reasonable total cost? Does rab without serial number behind it means it's rab 32257?
O don't think I will buy something that expensive for a project that is for myself only. But is good to know for feature if I want to make another pair of IEM's. Maybe that time I will choose better drivers and get more info regarding the driversHere is the testing microphone and adapter I have used for years, to test out custom IEMs. Dennie Miller has been an awesome resource and extremely helpful with an question or product support issues. Hands down would recommend him and his business to anyone. He also sells Smaart software. But, REW is still my go to software for ease of use. The adapter with this testing kit has a rubber gasket that stretches and holds firm to custom shell, eliminating thd need for the use if blue tack or any equivalent. Was a gamechanger for my development and growth. Thanks to @piotrus-g for setting me straight when I didnt realize the VALUE of such equipment.
Total: 13 (members: 0, guests: 13)
