chriswelsby
Anyway managed to get the computer to accept it but unfortunately the new firmware install made no difference. Not sure how my hardware is different from anybody else’s, if not firmware then what?
Sorry for not understanding but you got hold of a Windows PC or you installed it somehow using your MAC, I ask because I thought we had folks here try that with no success.Anyway managed to get the computer to accept it but unfortunately the new firmware install made no difference. Not sure how my hardware is different from anybody else’s, if not firmware then what?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Ok, I understand now. When you did the reflash what version of the firmware did it take you back to? If You remember by chance.I managed to convince my work PC to run the exe after some messing with the antivirus. Mac would need an emulator which I don’t have. As before I set the filter to GTO, it played fine, switched it off and back on and although still set to GTO there is no sound at all until moved to another filter setting. I mean the workaround is simple but I kinda liked the GTO sound.
Thanks again,It was 2.15 something a 2022 release
Yes I will try it. ThanksThanks again,
Is it possible for you to leave the unit on and see if there is a reset from GTO?
Cheers!!
Sorry to hear that but I would advise following support instructions.Sadly this did not work. Ifi support are talking about returning the unit which seems a bit drastic. I find it strange that this could be a hardware fault. The new firmware was 2.15.17 seems to work OK apart from the same issue with GTO.
I am sure they will, sorry for any inconvenience here.Well it’s not that it doesn’t hold , just that there is no sound. Yeah hopefully they will address.
Wow I am not alone. You describe the fault perfectly. Sadly updating the firmware will not fix it as I did that and no change. I did observe that this happens with uPnP and mconnect and Tidal connect but NOT Airplay with Qobuz. Might be worth opening a ticket so they know I’m not the only one.I have the same problem that explain chriswelsby. When i use the analog output, and the GTO filter is selected, there is no sound if i play a song. But if i select another filter turning the volumen, then the song start sounding.
I am using the 2.15.17 firmware versión, and i have to probe 2.16 that is the last one.
I suppose the question is, what are we doing different to everyone else? I use Wi-Fi with mconnect to play Qobuz songs from an iPhone XR.Wow I am not alone. You describe the fault perfectly. Sadly updating the firmware will not fix it as I did that and no change. I did observe that this happens with uPnP and mconnect and Tidal connect but NOT Airplay with Qobuz. Might be worth opening a ticket so they know I’m not the only one.
