mikp
- Jul 17, 2011
anyone know the mm size of the included tips L and xl?
was trying to find a pair to try on the xm5
Yeah, I love mine. FInally sold my XM5s and have Zero Regrets. I actually find the Techniques App far simpler to navigate and I'm thnkful I could use it customize the tap controls to something that was intuitive and made sense to me, instead of being stuck with the an illogical sequence I couldn't remember (Sony) . When you say "interrupt" feature, what are you referring to? Notifications? I'm on Android and have none.Brilliant buds, thus far. Picked up a pair last week after learning that my bricked XM4s are no longer repairable due to a parts shortage. Sound, comfort and battery life are all excellent and while the app feels a bit clunky still to me, it's perfectly usable.
I do find these keep pausing with the "interrupt" feature, however. Will keep playing with the app and see if I can sort it out.
THIS!I actually find the Techniques App far simpler to navigate and I'm thnkful I could use it customize the tap controls to something that was intuitive and made sense to me, instead of being stuck with the an illogical sequence I couldn't remember (Sony) .
Just a heads up guys,, these foam tips are quite good, they do fall apart after a few weeks though but, your getting 10 pairs for £13 though.. Btw only small and med size tips fits in the case.
https://www.amazon.co.uk/SONICFOAM-Memory-Foam-Earbud-Tips-SF1-Black-5-8-6-5mm-See-chart/dp/B09L7CX9JD/ref=sr_1_3?crid=1OW2O8QIF6MU&keywords=sf1+earbud+tips&qid=1703905733&sprefix=sf1+earbud+tips,aps,87&sr=8-3&th=1
I've been using Azla Sedna Short and Azla Sedna Crystal (not the tws version} and they both Grip and sound beautiful with AZ80s and fit in the case no problem. Of course, slow rebound foam isolated better, but these Azla options sound rich full and completely unrestricted. In the gym, I don't even need the ANC. when I go cycling with these tips, ANC cuts all the wind noise and these tips still grip.Thanks for this Phil - glad I won't have to get rid of the SONICFOAM tips after having used XM4s.
I know it's generally subjective, but do we have any other go-to tip choices for these? I usually go for different sizes on each ear as one is larger than the other.
The tips wont fit from the xm4s to the az80s,, you need the SF1 version of the SONICFOAM tipsThanks for this Phil - glad I won't have to get rid of the SONICFOAM tips after having used XM4s.
Thanks for sharing this!Another outlier that I didn’t put too much thought into was the AirPod Pro 2’s...
Same here, when I decided to get my AZ80s I didn't consider AirPods at all.
But now...
I've spent a few weeks with AZ80s. And here is the outcome.
I'm completely satisfied with the sound signature. The only thing to mention is that in some songs the sound is pretty shrill, so it gets uncomfortable sometimes (not too often).
But I can't say I'm satisfied with the comfort. These are my first in-ear headphones, so maybe I'm just not yet used to having something actually in my ears, but I feel them pretty clearly, I would love to have a lighter feeling, to be honest
So after reading some opinions (including the one I'm replying to), I decided to give a try to AirPods Pro 2 (APP2s).
And here's what I'd like to share.
1. I like the sound signature of AZ80s over APP2s. Wider sound stage, deeper bass, and more prominent highs (like hi-hats). Sorry if my words are not professional enough to describe. But overall, music is more enjoyable with AZ80s.
2. Comfort-wise, APP2s are better for me. I suppose the comfort is a pretty subjective parameter, but APP2s push my ears less. They kind of don't go that deeply inside with the same sealing level.
3. The ANC in APP2s is remarkably better, compared when commuted by bus and ferry. There is a real difference.
4. The call quality from the microphones - APP2s are way much better, no doubt.
With AZ80s the person I talked to (while commuting) was suffering. And even though in general I was understandable, she would rather prefer to talk to me later, or to ask me to talk via the phone (not via the AZ80s). With APP2s it was a different story - even though some background noise was there, it was absolutely acceptable to continue the call. My voice was closer, cleaner, more natural, and was not muffled - so no suffering.
With the calls in a quiet environment, the difference is not that dramatic, but still there. You have no muffling with AZ80s, but it's still not as natural and clear as with APP2s.
So now I found myself in a situation where it's so hard to decide what to keep and what to return.
I'd like to use my TWS for commuting and for work calls (which I have a lot), so the advantage of APP2s is so powerful.
On the other hand, listening to the music is much more fun on AZ80s.
I might end up keeping both even though it was not planned to spend the double budget on my first TWS
UPD:
I forgot to mention above that overall the sound signature of APP2s surprised me - even though I like AZ80s more, the APP2s' sound turned out to be much better than I expected.
Also, I must admit their controls seem to be more reliable - no sensor touches but physical press actions and swipes for volume level. And the transparency mode is also much more natural than in AZ80s.
Same tips I'm using. Both the Sedna and Crystal work really well with my preference being the Sena which provides really balanced sound, open staging and preservation of the low end - and they Grip well too!My Sedna tips just arrived, significantly SQ improve over default tips.
