rick81
- Jun 19, 2014
And ibasso dx200 with Kann?
That is good to know. Are you listening to the Kann solely or through another amp. Do you find any difference. Let us know your views.Hey guys if you get chance check out ak70mk thread, I have Kann and mk 2, both great daps, but in my opinion kann wins sq, more weight simbalance on every note, equally impressive soundstage, also ability to change gain settings
I did some critical listening just my 2 cents
Both great daps but Kann is impressive
Intermittent Touch Screen Problems.
I've had my Kann for about 2 weeks now and I'm getting intermittent touch screen problems. Sometimes the touch is off. If I touch the Tidal line in the Store (and I'm sure I'm touching it in the right place) MOOV starts. Sometimes when I try to scroll no matter when I start the scroll the top item in the list acts as if it's touched.
These problems are usually fixed with a reboot.
Has anyone else had similar issues?
Do you think it's software or a flaky touch screen?
Other than that this is better in every way than my AK70.
Mp3 tag. But only dsf files support tagging. Dff files dont.Can anyone recommend software to edit dsf files. Ie titles and id tags and artwork it is a nightmare..
Hi,
I have been using the Kann for the last 2 weeks and so far my impression is that this is an incredible DAP. Soundstage in amazing with the Audeze iSine10. The only complaints that I have are:
I was wondering if we can use the USB Dac functionality with an iphone? this would fix the issue of not having Android and Google Playstore in the Kann. I tried to use the USB Dac with my laptop but that doesn't seem to work, although I have installed the driver and connected Kann and the laptop with USB cable. The sound still goes out of the laptop speakers and not the Kann
- Some high frequency notes can be harsh to the ears like piano for example. I don't know if this will be better after the burn-in. Anyone facing the same issue?
- It seams that it is not possible to play and pause with the touch screen. You can only do this with the buttons which seems to be fragile.
- 1000$ for a DAP and we even don't get a case! even te cases that are available in the market do not sufficiently protect the Kann
Thank you for your help
Can this be used as a DAC on Mac OS?
To answer:
the problem is across the entire system. I used the Tidal example because it was a particular occurrence, but that same problem as been experienced elsewhere - like in the album list of the on player tracks - as well.
I have the latest updates for both Kann and Tidal.
I agree with your logic. The problem has occurred in the native player app as well, so I think it's more system layer than Tidal layer.
