Hi Shetzu,
I have tried to connect my Kann as USB DAC to my Mac, but it is not recognised, which is unusual. Typically my Mac will instantly recognise external USB DAC devices, like my Mojo, HiFi M8, Fiio X5-iii and DX-200. I have tried to restart both my Kann and my Mac, albeit with no joy.
I have tried to connect it to my iPad using the Apple USB connector, and it seems to be recognised but it said that Kann USB DAC is using too much power thus it is not working.
By the way, I am using 2015 MacBook Pro 15".
Can you please shed a light on my issues?
Thanks.
I will help you here. Lets go by following steps.
FOR EVERYONE HOW TO CONNECT KANN TO MAC AS EXT DAC
1. Connect your USB cable to Micro USB port of Kann and the other end to your Mac Pro.
2. On the Kann you will see DAC icon . Just press that. See image below:
3. On Mac Pro, go to system preference and click on sound icon. Here you select Kann as external sound card.
4. You mac is ready to use Kann as external Dac.
5. If you are using Audirvana+ as app to play your HD music, you must go in its settings and select Kann as sound card. Check image below:
6. If you are using jriver app then on the top menu bar of app select tools. Check image below
7. You are all set to listen to your Kann as dac on your Macbook Pro.
8. If you need help let me know.
Cheers
