Thank you Shetzu for your answer. I have tried the USB Dac with my laptop and it works perfectly
I had another question regarding the Balance output. My earphones are jack 3.5. I couldn't test the balance output because of that. Will I hear a difference in sound between the balance and unbalanced output? if the answer is yes, could you recommend a good 3.5 to 2.5 adapter?
Thank you
Yes the balanced output sounds better. You need to get a balanced cable with 2.5mm plug. In case you want to use 3.5mm plug later the same cable can be used along with adapter 2,5mm female to 3.5mm male. You can get the Fiio adapter which is the best. I had posted the image few pages back.
