Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
activatorfly
Not advisable to try to compare TOTL buds with budget (<£30) ....i'm listening to/enjoying Graphene currently - being engaged in their sound signature as much as the Masya. They compliment each other perfectly...both excel & are completely non-fatiguing. The difference is the Masya due to it's superb imaging, wider and deeper sound-stage, manages to recreate the live feel of a venue - my first truly holographic experience with buds!How does that bud stack up to Rose Masya? Is it worth buying it when I have the Masya on order or is it not in the same league?
Ok thanks that puts the bud into perspective, I'd be hesitant to bring the Rose Masya out and about in fear of it getting lost, stolen or damaged somehow.Not advisable to try to compare TOTL buds with budget (<£30) ....i'm listening to/enjoying Graphene currently - being engaged in their sound signature as much as the Masya. They compliment each other perfectly...both excel & are completely non-fatiguing. The difference is the Masya due to it's superb imaging, wider and deeper sound-stage, manages to recreate the live feel of a venue - my first truly holographic experience with buds!
That's where the EMX500, Vido or maybe the graphene would come in handy if I purchase.
activatorfly
Exactly - Graphene are the ideal second pair....without compromising the quality of TOTL (- even held off buying them during the AE sale.) Pulled the trigger last week....Arrived yesterday - they do live up to the hype definitely imho! - you can tell the quality of better buds by listening to them at max volume for any distortion (- compared to cheaper PK2 buds which distort & rattle like crazy! lol)Ok thanks that puts the bud into perspective, I'd be hesitant to bring the Rose Masya out and about in fear of it getting lost, stolen or damaged somehow.
Just like what happened to a few of the guys here, my emx500 has started this cracking sound on the left side. Not to mention that I did not use it often since I have several other iems and earbuds. I wonder if its just incidental or if its because of poor quality.
activatorfly
I had the same issue with PK2's at a certain volume (also on the left hand side.) ...never used my emx500 - they're first on my list of phones/buds to sell!Just like what happened to a few of the guys here, my emx500 has started this cracking sound on the left side. Not to mention that I did not use it often since I have several other iems and earbuds. I wonder if its just incidental or if its because of poor quality.
hung031086
Looking for a earbud with relax sounding, good bass, not too much treble to replace my zen2. Cable is broken after a few months. I only use earbuds when i go to sleep. Any recommendations ?
hung031086
Send back to them or somewhere else can do that ?They could be re cabled
nick n
- Feb 3, 2011
The wire itself is most likely enamel coated so will be fine and will not oxidize if so, unless you don't like looking at that, or it starts to bow out of that spot in the cable badly.
You could always get some clear silicone as a patch for now and smear it into that spot with your finger ( using a glove of course ).
Then worry about recable later if that doesn't hold up.
nick n
- Feb 3, 2011
^unless there is some sort of warranty period for those. I don't know what that might be.
I would re cable if it was mine but I love to tinker with electronics
golov17
1 y warrantySend back to them or somewhere else can do that ?
hung031086
I contacted lee and waiting for his reply.
golov17
not sure if this is a warranty damage, though ....I contacted lee and waiting for his reply.
Total: 17 (members: 1, guests: 16)
