Good point on dual geometry, wondering if adding 2 strand of the Chiron to the Cleo 2 would be worth it? (Of course would depend on if effect audio would be willing to build it)
You would have to PM Suyang about the possibility of it. It really depends on your budget if you can upgrade to Chiron bespoke. Chiron is one of those cables that truly makes a very noticeable difference in soundstage width and layering, though it will affect tonality as there's no way around that if you just want to keep the tonality unfortunately. The OCTA Cleo II though is a much safer bet, and 4x cheaper than Chiron for the upgrade and you'll definitely increase depth perception than just the 4 wire version as I have observed with Cleo 1 4W vs Cleo 1 Octa
Side note: 8 wires are sexy AF and after having 8W, it's truly hard to go back to 4W as my main cables
