Post your computer specs!~
Dec 9, 2023 at 6:52 PM Post #3,016 of 3,098
Decided to go with the lian li. Much bigger than I thought it'd be. Very nice case flows air real nice.
Still trying to figure out why its not booting if I add two more ram sticks though.
JsFJ3Pq.mp4
https://imgur.com/JsFJ3Pq
Dec 9, 2023 at 6:57 PM Post #3,017 of 3,098
JsFJ3Pq.mp4
Is it supported on QVL list for supported rams?
Dec 9, 2023 at 7:04 PM Post #3,018 of 3,098
You did read the MQL list for supported rams?
Yeah it's supported.
Works with 2 of them, ugh i think i might have a bad ram stick.
Gotta test them all individually...
Dec 9, 2023 at 7:07 PM Post #3,019 of 3,098
Hmm. Latest BIOS?
Dec 9, 2023 at 7:10 PM Post #3,020 of 3,098
Hmm. Latest BIOS?
Yep did that.
Updated all of the drivers.
Weird, it won't boot even into the bios with 4 dimms installed. Its fine with two though.
Dec 10, 2023 at 3:48 AM Post #3,021 of 3,098
Yep did that.
What CPU are you using? What is the speed of the RAM?
If it's and AM5, and your RAM is DDR5 above 5400, then yeah four DIMMs might not work.
I have 2x DDR5/6000 and it barely works right.
Dec 10, 2023 at 5:08 AM Post #3,022 of 3,098
Its an i9-14900k, 4x 16gb ddr5 6000 ram.
Is there some kind of limitation with that speed ram?
Dec 10, 2023 at 5:16 AM Post #3,023 of 3,098
oh my 6000😅😅
Just disable eveything regarding ram and tweak to lwer latency instead.
Much better system stability.
Atleast run them at the supported speed recommended on Intels specs.
Forget tweaking memory it ain’t worth it, waste of time, time, time, money and latency/speed….and lots of heat…
Edit: I just looked at the spec
Holy moly it supports 5600Mhz in DDR5!
Up to? - but what are the safest/stable speed?
Dec 10, 2023 at 6:00 AM Post #3,025 of 3,098
Dec 10, 2023 at 6:06 AM Post #3,026 of 3,098
Yeah thats the bundle that I got.
I think its the cas latency, its quite poor for that ram. Can't even OC it, its already maxxed out.
I guess I'll have to return the additional dimms and settle for 32gb for now.
Are 4 dimms supported? That bundle has 2. QVL for my mobo lets you know how many sets are supported.
I would try other memory to see if it starts.
Dec 10, 2023 at 6:10 AM Post #3,027 of 3,098
@dougms3 if it is dual channel and not a quad CPU. Best practice keep it dual :wink:
thats my speed even though it supports 3200Mhz. Never had better stability and better responds.
When manufacture release ram, the chip have the actual speed. That speed is always best, unless you get one of those sweet samsungs at 3200Mhz where its stock speed and no XMP/Weirdo profile....
Ram overclock is cool if you like numbers in synthetic benchmarks. In real world the actual speed always wins overall no matter what application.
Dec 10, 2023 at 6:54 AM Post #3,028 of 3,098
Lol not doing that because it's a bundle.
Defeats the purpose of the bundle. If i get different ran is no longer worth it.
I'm more familiar with AMD am4 platform. Never had issues with it. I guess it's also because the i9 14900 and 1700 lga are much newer, probably gonna be at least a year or so for the Mobo manufactures to update the bios with a wider range of RAM support.
Dec 10, 2023 at 12:10 PM Post #3,029 of 3,098
NM, you said 2 dimms work. I thought you had issue with even 2 sticks, in whicb I'd swap rams if I had spares around. check if 4 dimms supported on QVL.
I have a set of dual ranks that is supported my my mobo if I go 4 sticks. depends on memory controller
I believe dual ranks typically get supported for 4 dimms
Dec 10, 2023 at 12:30 PM Post #3,030 of 3,098
You don't use XMP? I would try the XMP and run stability
You are missing out on the shorter CAS latency and the higher clock
