Fegefeuer
- Mar 17, 2011
@Empyah might
Not with the Auteur or Aeolus, but my Verite sounded great with my then V281.Good Day. Anyone here has tried this with ZMF Auteur and Aeolus?
Maybe good enough? But definitely not like a power amp.Is it power enough to drive the Abyss 1266 and Susvara ?
Thanks for your reply..Mmm 3.8W already very powerful for most of the cans but still not good enough for Susvara.Maybe good enough? But definitely not like a power amp.
Susvaras impedance is around the 226's peak power of 3,8W.
I guess the V340/80 should get you there in terms of power with 5W at 50 Ohm, or V550/90 with ridiculous 6400mW at 50 Ohm with XLR ins and outs.Thanks for your reply..Mmm 3.8W already very powerful for most of the cans but still not good enough for Susvara.
Hi.
Sorry my english is not the best...
So I beg your pardon.
I would also like to say that the Violectric is my first headphone amp.
I have been using the Violectric DHA V226 since 02/17/2022.
The Violectric arrived safely packed.
The volume control sits firmly on the potentiometer and nothing wobbles.
The gap dimensions are even.
The processing quality is excellent.
What I noticed, however, is that when I turn the volume control to the left and right between 12 p.m. and 3 p.m. (without a signal), there is now and then a slight scratching of the headphones.
I use the DHA V226 with Audeze LCD-2 Classic headphones.
The headphones are connected to the Violectric via a ready-made XLR cable.
My first listening impression:
I have owned some CDs for over 30 years and I have never noticed so many details.
In my opinion, the combination of Violectric DHA V226 and Audeze LCD-2 Classic is a great combination.
As I said, both devices are not burned in yet.
I haven't used the amp's DAC yet because I don't have the gear.
I listen exclusively through a SACD player and use a turntable with a phono preamp.
The only thing that bothers me so far is the scratching when moving the volume control.
Therefore, the company will turn to Violectric.
When the devices are burned in, I will post a summary again here.
Could very well be the choice of headphones. The HD58x aren't the most precise in the bass (high distortion) and they have much more bass than the HD650 for example and B&W are generally boosted quite a bit in the bass.I just posted something in the V340 thread after seeing a comment there, but thought I should put it in here too as it's the more appropriate thread:
I picked up a V226 in December. Out of the box I found it very fatiguing. I didn't have much time to listen to it due to COVID issues and school holidays over here. But I returned to it every now and then and slowly clocked up some hours on it. I was using it with B&W P7s and HD58X, in single-ended (the former) and balanced (the latter).
It has a good sound stage, better than the Arcam rHead I had as a desktop amp for a while, and has the similar open-sounding mids as the Chronos. But I found the bass too overwhelming, and it could get fatiguing after a short time. Reducing the gain certainly helped take off the too-aggressive edge I was hearing, but even afterwards it just didn't gel with me. Needless to say I was disappointed after thinking it would be a good match - the Violectric Chronos is probably my all-round favorite dongle so far, and has been for over a year, so I had high hopes
Interestingly I found using the Chronos as a DAC, fed into RCA, gave a better balance to the sound than the built in DAC, even though I imagine both must share very similar components and technical specs. Using Mojopoly as a DAC also gave some interesting results. But either way I still found it fatiguing. In the end I figured I should just cut my losses and keep searching, and the dealer has offered to help me sell it second hand.
Anyway, I don't post this to rain on anyone's party - if you like it, keep on liking it But I figured I should post my experiences to help anyone else considering it.
I’ve heard my headphones through lots of different gear, including other desktop amps such as the rHead, Massdrop CTH, even RNDAC, as well as more powerful portable players. I used to have Aoen closed V1, keen to try V2 at some stage.It's not the amp my friend - you just heard your headphone for the first time. Get a decent DAC for an amp like this.
And judging by your description dynamic headphones are not for you. Get something like a DCA Aeon, Ether 2 or an egg shaped Hifiman, which are much less dynamic, much smoother.
Sorry, these all seem sub par for 300 Ohm Sennheisers.I’ve heard my headphones through lots of different gear, including other desktop amps such as the rHead, Massdrop CTH, even RNDAC, as well as more powerful portable players. I used to have Aoen closed V1, keen to try V2 at some stage.
