iscorpio71
Here's one for your amusement:Where are the photos and your impressions?
And expectations met reality? In sound, overal quality?Here's one for your amusement:
Expectations meet, soundwise it's very revealing and not forgiving of the recording quality.And expectations met reality? In sound, overal quality?
Thanks, after all such amp dac meant to be used wired but ofcourse it would be better if bluetooth worked as it should. But it should be fixed in the future. Its very fresh product. But sound should be revealing in this level of gear so for me it is as should. Good to hear anything about this product so thanks for sharingExpectations meet, soundwise it's very revealing and not forgiving of the recording quality.
My only complaint thus far Is the Bluetooth connection, as it suffers from jitter, very annoying. I guess and hope that it's going to be solved with a firmware update.
Best
It's meant to be used whichever way, but yes, wired has the most sound quality.Thanks, after all such amp dac meant to be used wired but ofcourse it would be better if bluetooth worked as it should. But it should be fixed in the future. Its very fresh product. But sound should be revealing in this level of gear so for me it is as should. Good to hear anything about this product so thanks for sharing
Dear friend,I'm going through the same problem.
Fiio does not have a store or representative in my country, I always have to import from China and pay customs taxes and there is also the risk of being blocked from entering the country, entry is not always allowed.
But historically Fiio products have always surprised me with their audio quality, I have never regretted purchasing them and whenever I need to sell the sale is done quickly due to the good reputation of quality that Fiio products have.
With this in mind I placed my order for a Fiio K9 AKM unit that has already arrived in my country and is currently being inspected, I hope it will certainly enter my country, eagerly awaiting the news and tax amounts.
Brasil.Caro amigo,
Em que país você está localizado?
Atenciosamente
Dear friend,Brasil.
"Am I correct in thinking that the front ON/OFF button only turns off the amplification and the DAC part (standby mode)?@FiiO
Estou correto ao pensar que o botão ON/OFF frontal apenas desliga a amplificação e a parte dac (modo de espera)?
Desligando o K9 através do botão ON/OFF frontal (modo Standby) a fonte de alimentação linear do K9 permanece operacional (modo standby) neste caso o calor ali gerado seria exclusivamente devido ao funcionamento da PSU Linear correto?
Olhando vários outros Dac Amps notei que no modo standby o calor gerado era apenas da fonte PSU e não da parte Chip Amp como alguns relataram em relação ao K9, neste caso o K9 só ficaria realmente frio se o standby o modo foi desligado usando o botão traseiro que corta 100% da energia da PSU, correto?
Alguns de vocês que já têm o K9 há muito tempo sempre o deixam no modo standby sem danificar o aparelho?
Dear friend,@FiiO
At the moment i found only one review in head fi, but there is comparison with ess version of k9 and k9pro. Not with k9pro akm, which was limited version and not so much have it.I think it will be really hard to find such version. Actually there is still not so much info about newest k9akm compared to anythingHello! Has anyone compared the Fiio K9 pro AKM with the Fiio k9 AKM, is there any difference in sound?
Dear friend,Hello! Has anyone compared the Fiio K9 pro AKM with the Fiio k9 AKM, is there any difference in sound?
