wastan
- Jun 13, 2015
I can check but I feel like they would be awesome on the 400i
FYI, an Amazon reviewer said the pads are 5" wide (130mm). Assuming that's a reliable measurement, you may want to measure your cans and see if anything can use pads that size (assuming they're removable).
Mine are approx. 112mm outer diameter. They seem to be glued down.
